WTB: Dellorto PHBH26CS carburetor cota 315R
Mk1finks
31 minutes ago, konrad said:
So the body itself has a damaged thread?  This part won't fix it? https://www.splatshop.co.uk/dellorto-float-bowl-nut.html
If not, can you run a tap into the body and clean it up?
Here's the entire carb with the BS suffix (your jetting may be different) https://www.splatshop.co.uk/dellorto-phbl-trials-carburettor.html
No, the bolt is fine, the body lost the first 3 rows of threads the bolt goes into. I didn’t have the pin that holds the float flapper seated enough and it held the bowl from seating but I didn’t notice. So it wasn’t sitting flush so I kept tightening it. Tbh I wasn’t reefing on it I had a stubby ratchet and I wasn’t giving it much. But when it skipped (almost like the ratchet missed a tooth) I knew I was in trouble.
46 minutes ago, robido said:
Try eurocarb
I believe ive been talking with Robert. Not sure if he implied that I’m toast or if he had a solution. He did say the CS is discontinued which is what brought me here.
2 hours ago, Mk1finks said:
Is it needing anything done to it? Im starting to think I’m carb-illiterate….
No, it's good to go, I swapped it for a Keihin out of curiosity.
If you're interested, message me, I'll strip it and send some pictures.
