Nedly Posted March 19, 2024 Report Share Posted March 19, 2024 I purchased a 2023 300 Gas Gas txt Gp in the USA. Is it possible to covert it to a 250 by putting on a 250 cylinder, head and piston on it. My issue with the bike is it has to much compression for me to start it. I can start it but during the course of a trials event it it wears me out. I’m a 66 year old intermediate rider that weighs 150. Im not concerned about power, I just want to make it easier to kick. I would b open to any other suggestions like a low compression head etc…. Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted March 19, 2024 Report Share Posted March 19, 2024 Not sure myself on if it can be converted but I would expect at the latest you can get a low compression head/insert. hopefully someone else knows the exact answer. Quote Link to comment Share on other sites More sharing options...
robido Posted March 19, 2024 Report Share Posted March 19, 2024 (edited) Put a extra base basket on will and make it softer and easier to start Edited March 19, 2024 by robido Letter missing Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted March 19, 2024 Report Share Posted March 19, 2024 @Nedly S3 PARTS Spain make a head and low compression insert for your bike it costs £153.00 in the UK I think you should find S3 parts for sale in the USA at a Trials dealer , if you cannot find it then go to www.trialendurodirect.com in the UK. Quote Link to comment Share on other sites More sharing options...
faussy Posted March 19, 2024 Report Share Posted March 19, 2024 (edited) 21 minutes ago, Tr1AL said: @Nedly S3 PARTS Spain make a head and low compression insert for your bike it costs £153.00 in the UK I think you should find S3 parts for sale in the USA at a Trials dealer , if you cannot find it then go to www.trialendurodirect.com in the UK. Theres no need to buy the complete inner and outter parts. AFAIK the s3 insert fits the standard 2023 style outter part. Id doubly check though. The inner part retails for around £60 Edited March 19, 2024 by faussy Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted March 19, 2024 Report Share Posted March 19, 2024 3 minutes ago, faussy said: Theres no need to buy the complete inner and outter parts. AFAIK the s3 insert fits the standard 2023 style outter part. Id doubly check though. The inner part retails for around £60 Makes sense , S3 have been making the cylinders , front pipes for GASGAS for years , these days I have to be careful what I assume as every one these days seems to be seeking ways to have less compatibility of products. 1 Quote Link to comment Share on other sites More sharing options...
Nedly Posted March 19, 2024 Author Report Share Posted March 19, 2024 Thanks for the help. I will do my research. Quote Link to comment Share on other sites More sharing options...
Strutty Posted March 20, 2024 Report Share Posted March 20, 2024 they run the same crank, can just do barrel and piston swap , find a good second hand barrel and crack on Quote Link to comment Share on other sites More sharing options...
lineaway Posted March 21, 2024 Report Share Posted March 21, 2024 On 3/19/2024 at 12:47 PM, Nedly said: I purchased a 2023 300 Gas Gas txt Gp in the USA. Is it possible to covert it to a 250 by putting on a 250 cylinder, head and piston on it. My issue with the bike is it has to much compression for me to start it. I can start it but during the course of a trials event it it wears me out. I’m a 66 year old intermediate rider that weighs 150. Im not concerned about power, I just want to make it easier to kick. I would b open to any other suggestions like a low compression head etc…. You are wasting your time. Sell it and buy a Beta 200 or a 250. Quote Link to comment Share on other sites More sharing options...
gasgasman280- Posted March 21, 2024 Report Share Posted March 21, 2024 Yeah sure.....and go to very average brakes, very average forks and a left hand ks. 🤪 1 1 Quote Link to comment Share on other sites More sharing options...
faussy Posted March 21, 2024 Report Share Posted March 21, 2024 Put an electric start on it https://www.greenlandmx.co.uk/en/electric-start-kit-txt-pro-contact/ET80001CT-CKW-1.html Only £1500 😀 Quote Link to comment Share on other sites More sharing options...
lineaway Posted March 21, 2024 Report Share Posted March 21, 2024 5 hours ago, gasgasman280- said: Yeah sure.....and go to very average brakes, very average forks and a left hand ks. 🤪 A bike is worthless unless it starts. Quote Link to comment Share on other sites More sharing options...
Nedly Posted March 21, 2024 Author Report Share Posted March 21, 2024 Thanks all. The bike starts, just take a lot of energy. I did learn a good trick to start it. Put it first gear, roll it back then pull in the clutch and kick. Seems easier to kick and probably starts 9 out of 10 times on first kick. Before this I would look for a tree to lean on so I could give it a solid kick. Now I start it like a normal rider. Probably going to a lower compression head. But not afraid to explore all options. Quote Link to comment Share on other sites More sharing options...
Glayne Posted March 21, 2024 Report Share Posted March 21, 2024 I would be interested in whether you find it much easier to start with a lower compression head or insert. Mine was a pain in the ass to start (280) until I learned the sharp fast kick required. Quote Link to comment Share on other sites More sharing options...
RonH Posted March 23, 2024 Report Share Posted March 23, 2024 I had the same issue with my 2023 Gasgas 250. It was an absolute pain to start. The piston has to be in the right position and you need the leg of a rhino to start it. Wore me out fast. My solution was to put a 1mm head spacer on it to lower the compression. It’s very easy to do and cost me about $25 to do it. It’s a different bike now. I got the head spacer from Trial Enduro Direct https://trialendurodirect.com/product/gg-pro-model-cylinder-head-spacer/?v=7516fd43adaa. It costs £12.75 and shipping to me in the USA was about another $12. I love it because it’s a lot less expensive than the S3 low compression kit and it worked. Good luck! 1 Quote Link to comment Share on other sites More sharing options...
