Knocking
coxy
hi i have an 06 gas gas 250 and use 70:1 mixture of putoline oil, when i open the throttle nd then shut it off quite quickly or let go of it there is a small knock noise as if the slide is hitting the bottom of the carb or something can anyone tell me what this is please??
cheers
i think that this has been a topic before but cannot find it
I am going to assume the bike is running when this happens? It's kind of a "clack" sound...like you tapped the motor with a small hammer? If this is accurate, it's likely a lean condition at idle causing this. It is sort of "pinking", which is caused by detonation and is normally noticed most under heavy load and open throttle...sounds sort of like a bag of marbles being shaken. This too is usually a sign of a lean condition.
If the noise your hearing is similar to what I described above, I suggest you turn the fuel screw (little brass slot screw on the side of the carb) out 1/2 to a full turn and see if it improves.
