MichaelW Posted May 5, 2024 Report Share Posted May 5, 2024 I purchased a 520-96 replacement chain for my 1986 Honda TLR200, and when it came, it is larger than stock chain, but everything I read says it should be 520-96 chain? Was stock chain a smaller chain non-O-ring chain? I also purchased new front & rear sprockets, and old chain seems to fit new sprockets, but 520-96 does not? Thanks in advance Mike Quote Link to comment Share on other sites More sharing options...
lineaway Posted May 6, 2024 Report Share Posted May 6, 2024 Chances are your 1986 is not a TLR but a Reflex. You should have counted the links and a trials bike should not use an o-ring chain. Quote Link to comment Share on other sites More sharing options...
timdog Posted May 6, 2024 Report Share Posted May 6, 2024 By larger do you mean the pitch? Was the old chain a 428, its stamped on the link. Which sprockets/ size did you buy. I run 520 chain with talon sprockets 10tooth front and rear is a Talon 214 48tooth 520 Quote Link to comment Share on other sites More sharing options...
MichaelW Posted May 11, 2024 Author Report Share Posted May 11, 2024 I ended up using old chain, it seems in good shape so it will work for now, new sprockets are Talon 10 & 48 thanks MW Quote Link to comment Share on other sites More sharing options...
