MichaelW Posted May 5 Report Share Posted May 5 I purchased a 520-96 replacement chain for my 1986 Honda TLR200, and when it came, it is larger than stock chain, but everything I read says it should be 520-96 chain? Was stock chain a smaller chain non-O-ring chain? I also purchased new front & rear sprockets, and old chain seems to fit new sprockets, but 520-96 does not? Thanks in advance Mike Quote Link to comment Share on other sites More sharing options...
lineaway Posted May 6 Report Share Posted May 6 Chances are your 1986 is not a TLR but a Reflex. You should have counted the links and a trials bike should not use an o-ring chain. Quote Link to comment Share on other sites More sharing options...
timdog Posted May 6 Report Share Posted May 6 By larger do you mean the pitch? Was the old chain a 428, its stamped on the link. Which sprockets/ size did you buy. I run 520 chain with talon sprockets 10tooth front and rear is a Talon 214 48tooth 520 Quote Link to comment Share on other sites More sharing options...
MichaelW Posted May 11 Author Report Share Posted May 11 I ended up using old chain, it seems in good shape so it will work for now, new sprockets are Talon 10 & 48 thanks MW Quote Link to comment Share on other sites More sharing options...
