nitjay - hrc Posted May 6, 2024 Report Share Posted May 6, 2024 (edited) Hi, Trying to get my bike trial ready again after a 10 year lay-off. How do you remove the rear shock on an SY250? I'm assuming once the bolt is out, both external spacers need to come out before the internal ones can be knocked out of the swing arm bracket. But could be completely wrong. I've removed the external spacer on one side, but on the other it's completely stuck - not sure what to try aside from WD40, hammer etc Any help would be appreciated. Cheers, NJ Edited May 6, 2024 by nitjay - hrc Quote Link to comment Share on other sites More sharing options...
nitjay - hrc Posted May 7, 2024 Author Report Share Posted May 7, 2024 (edited) I got the shock out - for future searches, use a flat head screwdriver under the bottom of the shock and pry it upwards. You don’t need to remove the bushes. Edited May 8, 2024 by nitjay - hrc Quote Link to comment Share on other sites More sharing options...
