1995 JTX clutch issues
Ash-hurcs
I have a 1995 JTX 250 and am having a few issues with the clutch I have removed clutch assembly and cleaned all parts also have checked and both pushrods and bell bearing in between are present I have bled clutch out I have adjusted leaver but still the clutch does not fully engage or disengage I have noticed the small ball bearing in the space cylinder has been pushed back into the cylinder so my question is do i need to replace the cylinder and seals or can I do something else to make it work better ??
Please help if you can it is fully appreciated .
thanks in advance
