Ninja Posted yesterday at 08:40 AM Report Share Posted yesterday at 08:40 AM Hi all could someone give me the dimensions for the brake drum insert,I believe cast iron pipe is used? TIA. Quote Link to comment Share on other sites More sharing options...
anotherclean Posted 4 hours ago Report Share Posted 4 hours ago I found it not that simple and ended up skimming the chrome off to get a clean surface, don't over do it, I then got a Westwood cylinder liner, sized and pressed in and turned it internally to 120mm and used Kawaski brake shoes 120mm x 30mm which just fit with some trimming and adjustment, we made about 5 from 1 liner. That was a long time ago, no drawings, just touch and feel, they worked well, better than original but Montesa cota wheels are equally good Quote Link to comment Share on other sites More sharing options...
