infusemoto Posted July 31, 2024 Report Share Posted July 31, 2024 my 2004 rm85 starts full throttle at start up and I put a brand new carb on it the throttle moves the needle is where its supported to be i don't know what to do. Quote Link to comment Share on other sites More sharing options...
lemur Posted July 31, 2024 Report Share Posted July 31, 2024 ... and the idle adjuster screw does nothing? Most likely cause; you have a round carb slide inserted 180 degrees from where it should be, a pin goes into a slot in the side of the carb slide and on the other side is a ramp where the idle screw pushes against. Quote Link to comment Share on other sites More sharing options...
faussy Posted August 1, 2024 Report Share Posted August 1, 2024 Is your slide fully closing? Quote Link to comment Share on other sites More sharing options...
infusemoto Posted August 1, 2024 Author Report Share Posted August 1, 2024 7 hours ago, faussy said: Is your slide fully closing? it almost completely closed Quote Link to comment Share on other sites More sharing options...
faussy Posted August 1, 2024 Report Share Posted August 1, 2024 Then you must be drawing in air somewhere else, intake boot possibly Quote Link to comment Share on other sites More sharing options...
tshock250 Posted August 4, 2024 Report Share Posted August 4, 2024 Slide "almost completely closed" What does that mean?, are you saying the slide is not closing? theres your issue. Quote Link to comment Share on other sites More sharing options...
