cedrica Posted Monday at 07:42 PM Report Share Posted Monday at 07:42 PM Hello everyone, I have a problem again with my Vertigo Busto 2021 250cc and I can't find the solution. I would like to post the problem to see if you have a solution. Some time ago, I had fueling problems during training. Thinking that dirt had gotten into the air screw of the injection body, I dismantled the injection body. I noticed that the tps sensor was free with the screw loosened.. Since then, it's been a mess! The motorcycle starts cold but rattles and smokes abnormally then when hot it stops by itself. Here's what I did: TPS Replacement TPS recalibration ----------The problem remains the same------ Checking the connections, checking the coolant level and pump operation, swapping the ignition coil with my brother's motorcycle I have no results The bike always stalls hot My WIFICOM does not indicate any fault What do you think? When I changed the TPS, I did the replacement without doing any tilt adjustment, just a calibration afterwards. do you think it's good? Thanks in advance 3 weeks since I rode............ Quote Link to comment Share on other sites More sharing options...
cedrica Posted 14 hours ago Author Report Share Posted 14 hours ago Hello everyone, It seems that the problem comes from the calibration of the TPS. The calibration we do on WIFI COM is not enough in most cases. A dealer has to burn the motorcycle on the computer to do a more thorough dealer calibration. That said, motorcycles after 2022 are no longer concerned, this calibration is done on the bike. The information comes from the importer France. Now I can only wait for the reopening of the dealerships who are on vacation. Have a nice day Quote Link to comment Share on other sites More sharing options...
