lewcez Posted August 10 Report Share Posted August 10 How much putoline nf radiator coolant do I put in my 2003 sherco 250? Also how do I drain the old stuff out? Quote Link to comment Share on other sites More sharing options...
konrad Posted August 11 Report Share Posted August 11 (edited) Some water pumps have a drain screw. Otherwise, you’ll have to temporarily remove a hose. You may need to tip the bike to get out as much old coolant as possible. Refill so the tops of the radiator tubes are just covered. Run the bike for 30 seconds to see if any air was trapped in the system. Refill if necessary. Since there is no coolant recovery tank, any excess (due to thermal expansion) will just flow out the overflow hose. This is the correct level. Edited August 11 by konrad Quote Link to comment Share on other sites More sharing options...
