Assgas Posted August 11, 2024 Report Share Posted August 11, 2024 (edited) My wife has a 2002 Gasgas 200 txt About 4 rides ago I put in new plates and fingers and bearing and it was like new again . Today started out with a easy one finger pull then in a couple hours it got hard to pull 2 finger . No drag or slip What could be the problem ? Edited August 11, 2024 by Assgas Quote Link to comment Share on other sites More sharing options...
faussy Posted August 11, 2024 Report Share Posted August 11, 2024 (edited) Plates swollen? Recheck your pack thickness. Check your centre bolt too Edited August 11, 2024 by faussy Quote Link to comment Share on other sites More sharing options...
Assgas Posted August 11, 2024 Author Report Share Posted August 11, 2024 Clutch does not drag at all It just got allot harder to pull Quote Link to comment Share on other sites More sharing options...
lemur Posted August 11, 2024 Report Share Posted August 11, 2024 It's hydraulic is it not? does it take DOT fluid or mineral oil and did you use the wrong thing or is the master cylinder just seizing from old DOT fluid corrosion? If it was tight at the slave end it would more likely jam on so I would say check the clutch master cylinder plus make sure it's not just tight at the lever pivot. Quote Link to comment Share on other sites More sharing options...
konrad Posted August 11, 2024 Report Share Posted August 11, 2024 On 8/11/2024 at 1:33 AM, Assgas said: Today started out with a easy one finger pull then in a couple hours it got hard to pull 2 finger. Expand Maybe the finger just got tired? Human evaluations are subjective. I've used a fish-weighing scale to quantify how much force it takes to pull a lever. Quote Link to comment Share on other sites More sharing options...
Assgas Posted August 11, 2024 Author Report Share Posted August 11, 2024 When she first got this bike clutch pull was 4 finger I took it apart inspected it all looked okay just worn . I put it back together pull in the lever it was so easy I thought I have to bleed the clutch Nope put in gear and it was good . Now it getting hard Quote Link to comment Share on other sites More sharing options...
lemur Posted August 11, 2024 Report Share Posted August 11, 2024 You can rebuild the clutch master with all new parts for about 50 bucks once you identify the model. Quote Link to comment Share on other sites More sharing options...
faussy Posted August 11, 2024 Report Share Posted August 11, 2024 (edited) Pack thickness effects the weight of the clutch. Maybe not four finger weight but ive certainly had gg clutches change from 1 to 2 finger weights solely due to pack thickness. Or more specifically, finger height Edited August 11, 2024 by faussy 1 Quote Link to comment Share on other sites More sharing options...
Assgas Posted August 11, 2024 Author Report Share Posted August 11, 2024 Next week i will inspect everything 6 months ago I put in new plates fingers and bearing and it worked like is should The Gasgas doesn't get ridden that much Wife has two Vertago's Here in California she can't ride them in the summer stupid emissions thing Quote Link to comment Share on other sites More sharing options...
stpauls Posted August 14, 2024 Report Share Posted August 14, 2024 On 8/11/2024 at 8:36 PM, Assgas said: When she first got this bike clutch pull was 4 finger I took it apart inspected it all looked okay just worn . I put it back together pull in the lever it was so easy I thought I have to bleed the clutch Nope put in gear and it was good . Now it getting hard Expand Your clutch should be a one finger pull. Quote Link to comment Share on other sites More sharing options...
Assgas Posted August 14, 2024 Author Report Share Posted August 14, 2024 On 8/14/2024 at 8:19 PM, stpauls said: pull Expand Yup super easy Now has a pull like my 500 Quote Link to comment Share on other sites More sharing options...
Assgas Posted August 18, 2024 Author Report Share Posted August 18, 2024 Okay I took it completely apart I did not see anything wrong changed mineral oil and still has a heavy pull today I pulled the clutch lever on a 2002 Gasgas 280 and it was easier . The clutch does not drag at all .We let the guy with the 280 ride it He said its heavy Quote Link to comment Share on other sites More sharing options...
Assgas Posted August 18, 2024 Author Report Share Posted August 18, 2024 On 8/11/2024 at 11:13 PM, faussy said: Pack thickness effects the weight of the clutch. Maybe not four finger weight but ive certainly had gg clutches change from 1 to 2 finger weights solely due to pack thickness. Or more specifically, finger height Expand What thickness should be Quote Link to comment Share on other sites More sharing options...
lineaway Posted August 18, 2024 Report Share Posted August 18, 2024 9.75 mm and finger height 17mm. 1 Quote Link to comment Share on other sites More sharing options...
konrad Posted August 18, 2024 Report Share Posted August 18, 2024 Some applicable information here: https://www.ossa-efi.com/home/engine/clutch#h.844fxvcen1dt 1 Quote Link to comment Share on other sites More sharing options...
