stu109 Posted August 13, 2024 Report Share Posted August 13, 2024 Hi Can someone tell me how to remove the thermostatic fan switch on my 2013 beta Evo. It looks as if it justs pushes in and is held in by an O ring, but I cannot get the old one out. Thanks Stuart Quote Link to comment Share on other sites More sharing options...
lemur Posted August 13, 2024 Report Share Posted August 13, 2024 Search for '2013 beta Evo fan switch'. pictures show it to be threaded which only makes sense because there is some pressure there. Quote Link to comment Share on other sites More sharing options...
overdale Posted August 14, 2024 Report Share Posted August 14, 2024 The thermostat is held in by a circlip, so you'll need circlip pliers to remove that. For best access you'll have to drop the radiator out to the limit of the fan wires - you may have to release a couple of cable ties, then as the thermostat is quite a tight fit and I usually screw a self tapping screw into the back of it to help prise it out. 1 Quote Link to comment Share on other sites More sharing options...
stu109 Posted August 14, 2024 Author Report Share Posted August 14, 2024 Hi, thanks for the replies. The 4T switch is different from the 2T. I have removed the circlip, so will give the self tapping screw a go. Quote Link to comment Share on other sites More sharing options...
stu109 Posted August 22, 2024 Author Report Share Posted August 22, 2024 I have replaced the switch and the fan but the bike is still overheating when it stands running for a while. It looks to me as if the fan is running more slowly that I remember. Can anyone tell me what voltage I should be getting at the fan? Also does anyone know where the earth point is on the loom so that I can check the grounding? Thanks Quote Link to comment Share on other sites More sharing options...
lemur Posted August 22, 2024 Report Share Posted August 22, 2024 (edited) ~12 volts D.C. after the regulator ~20 volts A.C. output from the stator Edited August 22, 2024 by lemur Quote Link to comment Share on other sites More sharing options...
lemur Posted August 22, 2024 Report Share Posted August 22, 2024 Does your fan blow or suck air through the rad ? It's a DC motor so if it spins the wrong direction you have the polarity reversed. Quote Link to comment Share on other sites More sharing options...
stu109 Posted August 25, 2024 Author Report Share Posted August 25, 2024 Hi I only had 1.6 volts at the fan. Cleaned all the connectors particularly the one to the regulator. Now all works fine, so must have just had a bad connection. Thanks for all your help. 1 Quote Link to comment Share on other sites More sharing options...
stu109 Posted September 22, 2024 Author Report Share Posted September 22, 2024 Took the bike out today and it overheated again. Fan running slowly. Cleaned connections again, no joy. By chance can across this thread - As suggested disconnected the fuel solenoid (which was not working anyway) and fan now back up to speed. Quote Link to comment Share on other sites More sharing options...
