Fan Switch
stu109
The thermostat is held in by a circlip, so you'll need circlip pliers to remove that.  For best access you'll have to drop the radiator out to the limit of the fan wires - you may have to release a couple of cable ties, then as the thermostat is quite a tight fit and I usually screw a self tapping screw into the back of it to help prise it out.
I have replaced the switch and the fan but the bike is still overheating when it stands running for a while.
It looks to me as if the fan is running more slowly that I remember.  Can anyone tell me what voltage I should be getting at the fan?
Also does anyone know where the earth point is on the loom so that I can check the grounding?
Thanks
  • 4 weeks later...
Took the bike out today and it overheated again.  Fan running slowly.
Cleaned connections again, no joy.
By chance can across this thread -
As suggested disconnected the fuel solenoid (which was not working anyway) and fan now back up to speed.
