jimg Posted August 14, 2024 Report Share Posted August 14, 2024 I'm in need of a primary pinion gear for a Cota (white wonder) 349. This is the gear that is pressed onto the main shaft that meshes with the clutch basket gear. Does anyone know if other Cota models are the same? Any leads to finding this part is much appreciated. Thank you. Quote Link to comment Share on other sites More sharing options...
dr nosh Posted August 15, 2024 Report Share Posted August 15, 2024 Have you tried these guys yet? https://clasicaslegendarias.com/ Have a look and compare the part numbers of the Cota models listed. Quote Link to comment Share on other sites More sharing options...
