Cota 349 (51M22289) Primary Pinion Gear
jimg
I'm in need of a primary pinion gear for a Cota (white wonder) 349.  This is the gear that is pressed onto the main shaft that meshes with the clutch basket gear.  Does anyone know if other Cota models are the same?  Any leads to finding this part is much appreciated.  Thank you.
