greg Posted March 26, 2006 Report Share Posted March 26, 2006 just looked at mine, its silver,and its fine Quote Link to comment Share on other sites More sharing options...
jtt Posted April 6, 2006 Report Share Posted April 6, 2006 I haven't had one of the Trials Ohlins apart, but have had many of the MX/Enduro ones apart. This screw does not seal the nitrogen charge on a normal Ohlins shock. It is little more than a dust cap. The charge is sealed with a rubber under this screw. Still shouldn't hit regardless. I'd rather replace the screw with a low profile bit than grind the frame. Bushing swap is the right solution though. Quote Link to comment Share on other sites More sharing options...
sting32 Posted May 5, 2006 Report Share Posted May 5, 2006 If any of you guys would like to have your dampers modified to solve the above problem then please contact me. The bearing and mods to the frame DO NOT totally solve the problem. The reason for this is that you can not re-gas the damper with the existing grub screw configuration (as per above photo)!!!! Please call the following for the complete solution to the problem by a Ohlins engineer and any servicing requirements 07786 926501 <{POST_SNAPBACK}> What about those of us in the USA (who didnt see this thread back when) but discoverd same crap? In fact on this bike they put the shock in so that the screw, that gets damaged, is exactly 180 degrees out of picture in early posts... (facing the muffler side making it harder to notice). Would you describe what I have to have done to my shock, please? Quote Link to comment Share on other sites More sharing options...
