Oset advice
njtrials
I was hoping someone was still active on this Site and had some advice to help get my Grandsons bikes ready. The Oset website has little info and seems to be not updated.
Can someone help find a online manual or print version for a 16r and 20r.? Specifically I'm looking for info regarding the three adjustments (what they control) located on the backbone of the frame. I also would like to understand the suspension adjustments on the forks as well. If there is a active Oset online community that I'm missing please point me in the right direction.
Regards,
NJtrials
The three controls basically limit the power. Can't remember the order, which was which but easy to figure out
1 limits top speed so you can set it
2 Throttle sensitivity, how quick throttle responds as turn it
3 power, so can you alter max available power to prolong battery life.
Suspension adjustments are very limited, basically like cycle forks. Years since my lad had one but made suspension slightly softer/firmer
