From hot it mumbles and goes out
Simonelongus
Hello everyone
It's been a while since I've posted and in fact I've relapsed!!!
I bought back an Ossa , I was in love with it!! and from late 2012 so a 2013 even though it has the ECU marked still with 11 final.
I'm writing because I have a problem, when the bike is nice and warm it shuts off on me, like it's running out of gas, it revs up as I ask and then drops goes up and then drops all the time.
I don't know what to look at.
Unfortunately I had sold everything kscan harnesses etc....
I can't tell if it stops getting spark or stops getting gasoline for a few moments.
Thanks
Translated with DeepL.com (free version)
  • 1 month later...
Found the problem and solved it at great expense!!!
Eventually when the bike started to heat up the main bearings seized up.
I gave and then gave again to figure it out until they really seized and I figured out where the problem was.
The engine now has new bearings!!!
Question: is it a 280cc is it normal that at low revs it runs poorly and as soon as it gets up a little bit of revs it suddenly shoots out power?
I can't drive it much....
Is it a mapping problem or are they all like that?
Thanks
As konrad has said at least get your bike on the K-scan and start from there. It is what i must do on my bike if i can find someone to do it and then you know more about how your bike is running.
Thanks
No, it should have very linear power.  The 300 factory has a LOT of power as you run it up, but a regular 280 should be really nice ll along.
  I would suspect the TPS, but of course all the components work together. I suggest doing a compression test (throttle wide open, kick until gauge stops) and make sure it is good. Then get the cable (I can send software if you don’t have it anymore) and set everything up properly.
Thank you, I will try to build the cable.
I have many mappings that were given to me by the Italian importer.
As soon as I build the cable , I will update you.
Right now it's almost unrideable because at low revs it doesn't go it's very smooth, but as soon as it goes up the revs it goes off abruptly.
Thank you.
