Help me set up the carburetor dellorto phbl 26 bs 1994
nick1
Help me set up the carburetor dellorto phbl 26 bs 1994. Motorcycle Gas Gas 1994, 237cc engine. The old carburetor parameters that were originally when I bought the motorcycle.
35 Pilot Jet
108 Main Jet
D36 Needle
50 Slide
60 Choke Jet
350 Float Needle valve
At these settings the carburetor is probably leaking. He just doesn't eat. Then I bought a 200 valve from Float Needle and bought a Main Jet in all sizes. I started trying to change the settings, I just changed the Float Needle valve to 200 and Main Jet 122, but it didn’t do anything. It still pours. Could it be a problem with the floats? Their weight is 2.8 grams. Maybe the float chamber I have is 19 mm at the wrong level. What settings are needed for my 237cc engine. Maybe the float chamber level is wrong? Maybe you need more or less?
Edited by nick1
21 minutes ago, lineaway said:
You are missing the gasket for the float valve/ needle and seat.
Maybe I didn’t understand something, can you mark it in the photo? I am writing through a translator. Maybe I didn't understand you correctly
