OssaClark Posted November 1, 2024 Report Share Posted November 1, 2024 2015 TR300i Recently purchased this bike and had a hard time starting it. Fuel pump was suspect and was the problem. After replacement the bike fired up and ran perfectly for 10 minutes - until it stopped. No spark, tried different plugs - nothing. Do these bikes have a weakness in the spark creation department ? Anything come to mind after an engine removal but ran for 10 min after install ? Not enough time with this bike to know what the go-to's are. Everything seems to be plugged in and secure. Pulled a coil off another dirt bike but still no spark. Blue/black wire to coil does show a voltage signal on a digital meter when moving the kick starter. Quote Link to comment Share on other sites More sharing options...
kurtas Posted November 1, 2024 Report Share Posted November 1, 2024 Spark is not normally an issue, do you have any spark at all? I.e. if you hang on to the spark plug do you get a kick? Quote Link to comment Share on other sites More sharing options...
reggie Posted November 2, 2024 Report Share Posted November 2, 2024 try closing the spark plug gap to approx. 0.35mm I am assuming you have tried a NEW spark plug Quote Link to comment Share on other sites More sharing options...
