Rosscorob Posted November 2, 2024 Report Share Posted November 2, 2024 Hi folks. I've not long treated myself to a TRS One R 250 and was hoping you could please advise on what tools I should have in the garage for maintenance and repair? Size of socket sets etc? My knowledge is pretty limited so it will be a learning on the job scenario as stuff breaks and maintenance is required. Any advice greatly appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
trapezeartist Posted November 4, 2024 Report Share Posted November 4, 2024 This is a general answer, but I can't think there will be anything different about the TRS. Set of tee-handle Allen keys. The most commonly used are 4mm, 5mm and 6mm but you may need 8mm and 10mm as well (front wheel spindle, for example). Set of combination spanners. I think I only use 8mm, 10mm and 13mm on my EM, plus a big one (22mm?) for the rear wheel spindle nut. Set of screwdrivers. Pair of C-spanners for adjusting rear shock preload. Pointy nose pliers for gripping fiddly things. 1 Quote Link to comment Share on other sites More sharing options...
