Brakes for oset 20
LuisMP29
I have a breakdown in the promax brake caliper, which are not sold separately and have the characteristic of using dot 4.
Because of this, several scenarios present themselves to me.
1. Get an AVID JUICY clamp that is in good condition and enter dot 4.
2. repair the one I have, but I don't think it will work.
3. Change the entire system of both wheels for shimano.
Has anyone had to change the brake system?
I’d say replace with the choice of MTB brake system that fits your budget. The front is an easy bolt on swap. From memory you need to feed the hose through the frame and bleed to follow the original rear routing. Clarks, Shimano, Magura, Hope… pick whichever is readily available to you with spare levers offered too.
Edited by colin99999
Typo
