Weird 'stuff' Coming Out The Magneto Cover
thumps
The white petrol smelling creamy substance will be a mixture of your petrol / oil mixture and water. When whisked up they produce this creamy mixture.
This is more likely to be the following (accepting the fact that your bike does not lose coolant water).
Whats happening is that petrol / oil mixture is in your bottom end and is creaping past the mains seals into the flywheel cover.
Water tends to condense inside engines and flywheel covers and sits sometimes in a small pudle at the bottom.
They are then whisked together by the flywheel going around causing this substance.
This shouldnt be a problem unless you find that your bike is running with a weak mixture. As well as petrol getting out , air may get back into your crank and cause your mixture to become weak.
This will show itself in your bike reving high in idle or the bike continuing to rev higher than usual or idle and "hunt".
The bike may also start to over heat and pink , where you wil hear a knocking noise coming from the top end of the engine as the fuel pre ignites.
If this problem develops ou may ned to change you mains bearings as the slop in them i lifting the seal up and down allowing the petrol out and the air in. You will need to change the seals as well.
I'm sure you wont have to do this , as its a newish bike. :thumbup:
Good luck and drain that water out. :(
Edited by gasgas249uk
