ryanroz Posted December 21, 2024 Report Share Posted December 21, 2024 Hello, I recently picked up a used 2019 GasGas 125 for my son and I can tell someone has been into the carb. Can someone please tell me what the stock jetting is for a newer 125 with a Keihin at sea level and what jetting they typically use? Thanks! Quote Link to comment Share on other sites More sharing options...
lemur Posted December 21, 2024 Report Share Posted December 21, 2024 Carburetor performance is dependent on the engines ability to move air. Highly recommend you inspect the reed valves, test the engine compression and the integrity of the bottom end seals first. The engine needs to move air efficiently for the carburetor to operate to its best efficiency and no amount of carburetor adjusting can overcome that. Quote Link to comment Share on other sites More sharing options...
ryanroz Posted December 21, 2024 Author Report Share Posted December 21, 2024 Thanks @lemur. I get all that, just looking for what the stock jetting was on a 2019 125 or a new GasGas 125. The 125 is no longer sold in the USA Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 22, 2024 Report Share Posted December 22, 2024 The only thing Torrot shows was the 125 took a 52 pilot jet. So what elevation are you riding at? Quote Link to comment Share on other sites More sharing options...
peterh Posted December 22, 2024 Report Share Posted December 22, 2024 You can find lots of useful information at The HellTeam https://www.thehellteam.com/technical-support/gas-gas-parts-and-service-manuals a 2018 workshop manual and a 2020 manual should help. Expect it will be a standard Keihin jet setup for a 125: jjh needle, clip 3rd from top, 125 main, 52 idle with 1.25 to 1.5 turns out on air screw and then adjust as to needs. Quote Link to comment Share on other sites More sharing options...
