Does anyone know how thick the stock base gasket is on a GasGas gp 300?
castreuilo
Hello everyone,
I bought a 2020 Gasgas GP 300cc, with the red cylinder head, but I don't have the right compression, there was 1.2mm of base gasket, does anyone know what thickness is the original base gasket?
Thank you very much in advance.
Olivier from Belgium.
Ultimately, you want to use the base gasket (or gaskets) that gives a squish clearance compatible with your riding preferences, altitude, and local fuel.  This is done via experimentation.
As faussy mentioned, you should get a baseline by measuring your squish clearance. This link illustrates the procedure: https://www.vhm.nl/en/page/technical-support/squish-measurement   The "tin wire" is typically solder.
Notes I have on my old GG TXT321 say the minimum squish clearance is 1.25 mm.  Different thickness base gaskets are available partly to accommodate manufacturing tolerances, and partly for rider preference in power delivery (more squish clearance = softer).
When you measure the squish clearance, make sure the head and piston are free of carbon.
