Montesa 1980 349 no fuel getting through
E19HAD
Hi, final had time over Christmas to spend time with the Cota. Everything including carb and motor have been stripped and replaced with new parts. However, there seems to be no fuel getting through. Good spark and compression, but not the slightest glint of it starting. Any ideas?
So if you remove the float bowl completely and turn on the fuel tap, nothing comes out?  That would narrow the source of your problems significantly.
... is that one of the carbs where you can accidentally install the floats in backwards or upside down?
Expand
Hi, it's an Amal 2622 model and tbh the float could only go one way. Will give the carb a go now without the bowl attached 👍
Expand
More info needed. How far is the fuel getting?
After the float bowl is the main jet and emulsion tube which is the most common source of problems, that assembly can get pugged very easy.  The carburetor operates on intake vacuum pressure to draw fuel up through the emulsion tube and jets.
Expand
What is the best way to check and if so, clear the emulsion tube?
The Carb was totally stripped and ultrasonic cleaned before it was assembled.
  On 1/1/2025 at 8:06 AM, E19HAD said:
It doesn't seem to be coming out the main jet, but the float bowl is full.
Expand
Main jet is plugged or float bowl is not vented to atmospheric pressure or your engine is not producing sufficient vacuum to make the carb work.  Float bowl is not suppose to be full, it is suppose to maintain a level that is appropriate to the emulsion tube doing its job which is to initiate the atomization of liquid fuel into the intake path. The emulsion tube and main jet does that atomization of fuel by creating bubbles in the fuel but it can't make bubbles unless the fuel level in the float bowl is correct which is closer to half full not completely full.
