WIX-ONE Posted January 21 Report Share Posted January 21 Might be a daft question but are they universal or specific as i see some with the bike type referenced but others not? Which will fit an Epure race 2021? Cheers Quote Link to comment Share on other sites More sharing options...
konrad Posted January 21 Report Share Posted January 21 Rear brake levers are far from universal. Several criteria must be met. At a minimum: Diameter of pivot. Distance between pivot center-line to the actuation rod and pedal tip (determines leverage ratio). The EM has a "stop screw" to keep the pedal from flopping up and down. I'd recommend comparing your lever to photos of aftermarket replacements. The most likely substitution will be for Sherco/Scorpa circa 2020. If you find something that works, let me know and I'll add it to my website. Quote Link to comment Share on other sites More sharing options...
WIX-ONE Posted January 21 Author Report Share Posted January 21 Chee mate i will do. Spotted on a spanish site(https://trialworld.es/tienda-trial/en/brakes-and-hidraulic-system/2217-electric-motion-rear-brake-pedal.html) that the EM pedal fits these Gas Gas Pro/Racing/Raga/Factory 99-18, Jotagas 12-18, Ossa 11-16, TRS One 16-18, Vertigo Combat 16-18 so should work in reverse? I asked the guys at TrialsUK but they said the same about the Sherco so have ordered me in an Apico one. I'll let you know how it goes once i get it Quote Link to comment Share on other sites More sharing options...
