Rear brake pedal
WIX-ONE
Rear brake levers are far from universal.
Several criteria must be met.  At a minimum: Diameter of pivot. Distance between pivot center-line to the actuation rod and pedal tip (determines leverage ratio).  The EM has a "stop screw" to keep the pedal from flopping up and down.
I'd recommend comparing your lever to photos of aftermarket replacements. The most likely substitution will be for Sherco/Scorpa circa 2020.  If you find something that works, let me know and I'll add it to my website.
Chee mate i will do.
Spotted on a spanish site(https://trialworld.es/tienda-trial/en/brakes-and-hidraulic-system/2217-electric-motion-rear-brake-pedal.html) that the EM pedal fits these Gas Gas Pro/Racing/Raga/Factory 99-18, Jotagas 12-18, Ossa 11-16, TRS One 16-18, Vertigo Combat 16-18 so should work in reverse?
I asked the guys at TrialsUK but they said the same about the Sherco so have ordered me in an Apico one.
I'll let you know how it goes once i get it
