Shonkers Posted 11 hours ago Report Share Posted 11 hours ago Arrived home from short ride out and she revved up for no appararent reason i immediately thought throttle stuck open but no, then quickly fiddled with cable at the carb but no, tried kill switch but no(even at idle would take a second or two to knock off need new switch perhaps) put into gear but just spun back wheel up ‘cos was on gravel so let front brake off and aimed for tree 2 yards in front phew that did it, now struggles to start sometimes gives a pop or a fart but no start and sometimes will run for a few seconds then if you give any throttle dies. I took carb off checked an cleaned it all ok taped up split hoses to airbox and inlet swapped plugs but still doing same, have i done any major damage? it probably all lasted for about 8 seconds Quote Link to comment Share on other sites More sharing options...
Shonkers Posted 11 hours ago Author Report Share Posted 11 hours ago Btw it’s a ‘77 sherpa t 191 350 Quote Link to comment Share on other sites More sharing options...
bullylover Posted 8 hours ago Report Share Posted 8 hours ago Sounds like an air leak somewhere. Check both of your carby rubbers. Carb to barrel and carb to airbox. Also make sure the intake hose clamps are both tight. 1 Quote Link to comment Share on other sites More sharing options...
faussy Posted 7 hours ago Report Share Posted 7 hours ago 3 hours ago, Shonkers said: taped up split hoses to airbox and inlet So the hose from the carb to barrel is split and you've taped it up? Yeah, that's your problem right there 1 1 Quote Link to comment Share on other sites More sharing options...
Shonkers Posted 7 hours ago Author Report Share Posted 7 hours ago Iv’e ordered new hoses from inmotion it’s funny ‘cos was running ok till the rev up maybe i shouldn’t hav taped it up Quote Link to comment Share on other sites More sharing options...
b40rt Posted 5 hours ago Report Share Posted 5 hours ago 1 hour ago, Shonkers said: Iv’e ordered new hoses from inmotion it’s funny ‘cos was running ok till the rev up maybe i shouldn’t hav taped it up It could also be a crankshaft seal, if a new hose doesn't solve the problem. 1 Quote Link to comment Share on other sites More sharing options...
motovita Posted 4 hours ago Report Share Posted 4 hours ago If it's the original carb thats been sucking dirty air through a torn hose it may need replacement, or at least a new slide. b Quote Link to comment Share on other sites More sharing options...
Shonkers Posted 1 hour ago Author Report Share Posted 1 hour ago Iv’e read somewhere else on here that the rev up can happen with worn crank seals, i’m going to double check the carb ‘cos i did notice the slide had a few scuffs on it but thought it was working ok, thanks for replies chaps Quote Link to comment Share on other sites More sharing options...
