betatechno95 Posted April 4, 2006 Report Share Posted April 4, 2006 Anyone know the mix of oil to fuel for my techno 95, and is it poss if i dont get it right it would make my bike overheat?? Quote Link to comment Share on other sites More sharing options...
flossieawol Posted April 4, 2006 Report Share Posted April 4, 2006 Hi There, I run mine on 70 to 1 using good quality synthetic oil never had a problem Quote Link to comment Share on other sites More sharing options...
feetupfun Posted April 4, 2006 Report Share Posted April 4, 2006 If you don't have enough oil in your fuel, the friction from the rings and piston rubbing against the bore greatly increases. This friction can get the rings and bore and piston very hot. Aluminium expands more with temperature rise than steel and cast iron so as your bits get very hot, the clearance between the piston and the bore becomes too small. If this process goes far enough the parts may stick (sieze) together. Even if they don't get to the point of seizing, running an engine with insufficient oil will make the rubbing bits wear out faster than otherwise. The heating due to rubbing friction has nothing to do with the heat produced when fuel is burned in the engine. The amount of oil in your fuel has only a tiny effect on the amount of heat produced by combustion. Quote Link to comment Share on other sites More sharing options...
rapid roy Posted April 4, 2006 Report Share Posted April 4, 2006 I WOULD TRY 50:1 WITH A GOOD SYN 2 STROKE OIL Quote Link to comment Share on other sites More sharing options...
betatechno95 Posted April 4, 2006 Author Report Share Posted April 4, 2006 thanks a lot for your replys i will give it a go. you know more about it than me!! Quote Link to comment Share on other sites More sharing options...
