AJP/Braktec Master Cylinder
trapezeartist
Good trick question. Ajp went under. AJP made a better product. But Brakteh uses thier design in a different body. I use the old large body AJP. Mainly they are more dependable. But they use the same pistons more or less. The Braktec feels smoother when bled well. But I still get a firmer brake overall with the ajp.
  • Like 3
Over the years there were 2 different sized banjo hose fittings and the handlebar mount went from two bolts to one bolt with a hinge.  You will want to make certain your hydraulic fittings are the same or you will end up replacing the entire front brake assembly.
It is a trick question from the aspect that Brembo bought J.Juan which bought Braktek subsequent to their purchase of AJP so yes; there are a whole bunch of different model brakes all made virtually by the same company.
Photos are the best way to tell them apart 😕
  • Like 2
