mcman56 Posted February 25, 2025 Report Share Posted February 25, 2025 I have a 2018 300 with black throttle tube. It looks just like the 2T throttle. Is a slower one available? I have a 2016 Beta 300 4T standard model and the throttle has much more resolution for small blips, maybe 100% more resolution that makes throttle control much easier. Quote Link to comment Share on other sites More sharing options...
lineaway Posted February 25, 2025 Report Share Posted February 25, 2025 The black is the slower throttle. Have you geared the bike down at all? Most do at least 1 tooth larger in the rear. Quote Link to comment Share on other sites More sharing options...
lemur Posted February 25, 2025 Report Share Posted February 25, 2025 Blips is a 2-stroke habit and something that the 4RT does not like to do very much, the rider is rewarded through the use of a steady throttle hand. Quote Link to comment Share on other sites More sharing options...
mcman56 Posted February 25, 2025 Author Report Share Posted February 25, 2025 1 hour ago, lemur said: Blips is a 2-stroke habit and something that the 4RT does not like to do very much, the rider is rewarded through the use of a steady throttle hand. Interesting comment. Then, what would be the 4t technique for a basic double blip over a log? I went one tooth down on the front sprocket and that feels pretty good. Quote Link to comment Share on other sites More sharing options...
lineaway Posted February 25, 2025 Report Share Posted February 25, 2025 I think the 9 was over kill. That's like going to a 46 tooth rear. Puts you right in the middle of the power. If you look at a dyno of montesa power, the graph goes almost straight up from idle. I messed around, the 42 was almost good. A 43 was too low. So I ended up with a 9 and a 38. But I am on a 301 which is much quicker. Quote Link to comment Share on other sites More sharing options...
lemur Posted February 25, 2025 Report Share Posted February 25, 2025 5 hours ago, mcman56 said: Interesting comment. Then, what would be the 4t technique for a basic double blip over a log? I went one tooth down on the front sprocket and that feels pretty good. I use a higher gear range compared to some, apply the revs a little earlier and use the clutch a lot more to moderate the launch acceleration. 4RT power is extremely linear and almost endless compared to the 2-strokes that thrive on short bursts of fast throttle. 4RT also has 5 clutch plates (3 cork & 2 paper) instead of 3 corks like many of the 2T bikes, design theory was to offer better bite. Quote Link to comment Share on other sites More sharing options...
