trapezeartist Posted February 25, 2025 Report Share Posted February 25, 2025 I've just come across an issue with my Domino throttle. After a small inversion that has left the throttle with a minor scar in the plastic (which may be a red herring), it has become sticky. Off the bike or with the clamp screws loose, it is fine. As soon as I start to tighten the clamp screws the self-closing disappears. I've tried packing the clamps with a thin piece of plastic: no good. I've tried tightening the clamp screws with the throttle off the handlebar and it works fine. Any ideas? I'm reluctant to take the throttle apart because of the return spring and the alignment of the gears, but that is looking like it will have to be my next move. Quote Link to comment Share on other sites More sharing options...
Monty4T Posted February 26, 2025 Report Share Posted February 26, 2025 Has any mud or anything else got in between the throttle tube and the handlebar preventing smooth operation when the clamps are tightened, or the tube become bent after an off? Quote Link to comment Share on other sites More sharing options...
trapezeartist Posted February 26, 2025 Author Report Share Posted February 26, 2025 It was a slight (invisible) distortion of the housing caused by the bike landing upside-down. After much fiddling, poking and swearing I identified that when the half of the clamp that is integral with the housing was pressed hard against the handlebar, the throttle tube was binding against the bar. I couldn't get it to work by packing with a thin piece of plastic so used about three turns of PVC tape around the bar. I still can't tighten the screws as much as I would like but it is working now. Quote Link to comment Share on other sites More sharing options...
Monty4T Posted March 4, 2025 Report Share Posted March 4, 2025 Glad to hear you've identified the problem. Now its can you repair the old one good enough to use, or buy a new one? Quote Link to comment Share on other sites More sharing options...
trapezeartist Posted March 11, 2025 Author Report Share Posted March 11, 2025 On 3/4/2025 at 5:15 PM, Monty4T said: Glad to hear you've identified the problem. Now its can you repair the old one good enough to use, or buy a new one? It's good enough to use. Did a trial last weekend with no issues. Quote Link to comment Share on other sites More sharing options...
