n.wales_sherco_lad1 Posted April 9, 2006 Report Share Posted April 9, 2006 i have split my back mudgaurd the stickers are holding it together is there any way i could glue or plastic weld (i heard)? any suggetions would be appriciated thanks scott Quote Link to comment Share on other sites More sharing options...
gasgasthermo Posted April 9, 2006 Report Share Posted April 9, 2006 (edited) bend a peice a thin steel to the shape of the under side of the mud gard as you only need it on the bottom and rivet it eather side of the crack hope this helps!! Edited April 9, 2006 by gasgasthermo Quote Link to comment Share on other sites More sharing options...
sherco 125 Posted April 9, 2006 Report Share Posted April 9, 2006 i have done the same thing to my sherco where the screw that holds it on i drilled two holes either side of the crach and put a cable tyre hope this helps as it holds for quite long untill u flip or fall awquardly and strech the cable tyre Quote Link to comment Share on other sites More sharing options...
wiltshire_boy Posted April 9, 2006 Report Share Posted April 9, 2006 Broke my rear practising in the garden recently but managed to bodge it by Aralditing a piece of flexible perspex type stuff across the crack underneath then "plastic welding" (i.e. melting) around the edges with the fat tip on my soldering iron. It sure as hell don't look very pretty but seems to be holding. The fumes coming off it were probably best not inhaled though Quote Link to comment Share on other sites More sharing options...
