ev.. Posted April 10, 2006 Report Share Posted April 10, 2006 as long as I putter along in 1st I can hardly hear it the faster I go, the highter the gear the louder, harder the knocking gets I suspect it is the chain tensioner but am not sure anyone else experienced a strange knocking noise and can tell me how to get rid of it? could it be the fancy half-link in my chain? thanks for your help ev Quote Link to comment Share on other sites More sharing options...
yacapo Posted April 10, 2006 Report Share Posted April 10, 2006 i dont know about the noise, but how do you like the 2.9 compared to the gas gas? Quote Link to comment Share on other sites More sharing options...
chris Posted April 10, 2006 Report Share Posted April 10, 2006 Copied this from another thread This is usually the split link that has worn more than the rest of the chain, check the roller after the split link for markings (lines on the roller). Definitely worth trying a new split link anyway before you splash out on a new chain and sprockets. Make sure you get the right size split link as well, there are a lot of different pin sizes. Chris Quote Link to comment Share on other sites More sharing options...
ev.. Posted April 11, 2006 Author Report Share Posted April 11, 2006 thank you Chris the link next to the 1/2-link is the master and you are right, the rollers look more worn than the rest of the chain I NEVER before saw or heared of a 1/2-link do I NEED that? what for? if not: I have 2 new chains at hand a DID HD supertrallala MX chain and a DID VT Xring any reason not to use the X-ring chain? Quote Link to comment Share on other sites More sharing options...
ev.. Posted April 11, 2006 Author Report Share Posted April 11, 2006 ...but how do you like the 2.9 compared to the gas gas?right] cann't comment on which is better for trials the Sherco is snappier, I like the gearing better the Gassi feels torquier, the powerband seems smoother and she turns tighter Quote Link to comment Share on other sites More sharing options...
sirsherco Posted April 11, 2006 Report Share Posted April 11, 2006 Greetings, I Had the same mysterious noise ,baffled me for months ,thought it was a lose spoke ,no fitted new chain ,end of noise ,but check your tensioner also as it may be out of whack.The split link is for fitting when the chain has stretched and needs links taken out so you ,still use ,speedway boys use d to use them .Cheers from New Zealand. Quote Link to comment Share on other sites More sharing options...
howard wallace Posted April 12, 2006 Report Share Posted April 12, 2006 Make sure you get the original chain. They are actually listed as a specific trials chain, and are narrower than the MX or O-Ring type. You`ll chop the chain tensioner block up with the MX chain, and they come awfully close to the engine cases. Use a vernier and measure across the side plates and pin length, there`s millimeters of differance. ShercoH Quote Link to comment Share on other sites More sharing options...
