348mate Posted April 26, 2006 Report Share Posted April 26, 2006 (edited) Is there a recomended way to check whether front springs are worn out/soft? Can someone run me through the procedure for bolting forks axle etc together to eliminate "snatching" of the forks on rebound. many thanks, S.M. Edited April 26, 2006 by 348mate Quote Link to comment Share on other sites More sharing options...
348mate Posted April 26, 2006 Author Report Share Posted April 26, 2006 "snatching" i mean slight stickiness and forks not fully extending upwrds properly, without lifting bars slightly,. There is a bit of sag even with the bike riderless!! possibly the springs are shot. S.M Quote Link to comment Share on other sites More sharing options...
348mate Posted April 26, 2006 Author Report Share Posted April 26, 2006 Ta for the help, Quote Link to comment Share on other sites More sharing options...
348mate Posted April 28, 2006 Author Report Share Posted April 28, 2006 I bit the bullet and bought a new spring, it was a longer length than what was in the bike. and had one short plastic spacer. the old spring was shorter and had two plastic spacers, dont know if that set up was correct, Anyway with new spring/spacer fitted the bike now stands with forks fully extended at rest and seems much better.. thanks to all S.M. Quote Link to comment Share on other sites More sharing options...
neonsurge Posted April 28, 2006 Report Share Posted April 28, 2006 Shouldn't there be a small amount of sag in the forks (well, at both ends actually) when the bike is held upright and riderless? I'd always thought that this is called "static sag" and is used as the baseline measurement for suspension tuning ("race sag" is measured with the rider on the bike and both are taken from the middle of the axle to an arbitrary point on the front/rear mudguard with the difference between the two measurements determining the required preload adjustment.) Quote Link to comment Share on other sites More sharing options...
348mate Posted April 28, 2006 Author Report Share Posted April 28, 2006 Yep, should have said there is a small amount of "sag" when riderless.. but a lot less than before. S.m. Quote Link to comment Share on other sites More sharing options...
