maxi Posted April 27, 2006 Report Share Posted April 27, 2006 (edited) I've just fitted a second hand flat bashplate to my 03 SY250. It's in good condition and came complete with the four allen head mounting bolts and nuts and it was considerably cheaper than a new one. It came off a later model SY 250, a 04 or 05 model Fitting it correctly was a bit harder than anticipated and I have two questions: It only just misses (about 1 or 2mm at the closest point) the crankcase where the bolt connecting the magneto cover is at the lower front of the motor. In order to get this gap I had to tighten the rear bashplate mounting bolts first and then do up the front ones. Doing it in any other order resulted in the plate touching the crankcase. Is the 2mm clearance normal/sufficient? I can't imagine the plate moving or flexing and the original bashplate almost touched the crankcase at the same point anyway. The plate being 6mm thick is quite stiff and in order to screw it to the front mounts I first had to insert a longer bolt on one side and tighten it so I could then get the plate closer enough to the engine/bashplate mount to use the correct mounting bolt on the other side, tighten that up and then screw up the other side. I think I had to pull it in about 3cms. The front bashplate mounting holes are a vertical slot and when pulling in the plate the bolt starts at the top of the slot and ends up at the bottom, so it looks like that's what had to be done. With the thickness/stiffness of the plate there was a fair bit of tension required to screw the bashplate into position. Is that mounting procedure and tension in the bashplate when it's in position normal? The plate is not twisted or bent and when installed it is flat on the bottom. I had to extend the oil drain plug hole towards the front slightly so I could access the drain plug which has an allen key head without removing the bashplate. No worries, easy to do and negates the need to remove the plate for anything! The standard rubber block that sits between the between the plate and the bottom of the crankcase is in place. Cheers Edited April 27, 2006 by Maxi Quote Link to comment Share on other sites More sharing options...
jreilly Posted April 27, 2006 Report Share Posted April 27, 2006 Maxi,I have had several of the flat plates and they all seem to go on like that.Do you have the small rubber pad that goes between the mag side of motor,it is only about 2" by 4" inches but should be in there.Also it helps when you install plate to put bike stand under bike and let weight of bike push plate up.There always seems to be alot of tension on plate to put screws in place.Jim Quote Link to comment Share on other sites More sharing options...
maxi Posted April 27, 2006 Author Report Share Posted April 27, 2006 Jim Thanks for the quick reply. There was another bit of rubber that came with it, about 2 x 4 inches and 5mm thick but it was virtually split completely into two pieces which I Quote Link to comment Share on other sites More sharing options...
jreilly Posted April 27, 2006 Report Share Posted April 27, 2006 Maxi,Yes the small peice of rubbers tends to wear in half over time.But as small and as thin as it is it still cushions the case.JR Quote Link to comment Share on other sites More sharing options...
boofont Posted April 27, 2006 Report Share Posted April 27, 2006 I've got the none flat bash plate and I have to use molegrips to put it on. Quote Link to comment Share on other sites More sharing options...
maxi Posted April 28, 2006 Author Report Share Posted April 28, 2006 Sorted I've purchased some replacement rubber almost the same thickness as the original piece (about 5mm) Cut it to size Loosened the bashplate front mounts off sufficiently Wedged the rubber between the motor and the plate Retightened the bashplate squashing the rubber into position Thanks for your help Jim Quote Link to comment Share on other sites More sharing options...
eric23 Posted April 29, 2006 Report Share Posted April 29, 2006 My standard plate requires tension as you have described. I believe this to provide additonal structural strength to the frame. The longer bolt method works well for me. Quote Link to comment Share on other sites More sharing options...
