2002 315 Fork Seal Removal
donmurray
Forks are off the bike, damper is out, dust seal is off, and the circlip has been removed, but not sure how to remove the slider and seal. The manual say to pull out sharply on the fork tube to bump the seal out. Tried this a few times, but nothing moved. Should I heat the aluminum lower leg a little and then slide the tube out harder?
How do you read the stem head label to determine the build year?
