Help With Clutch Ty175
fatboyty175
hi ive got a dilemer with my clutch what it is is that i start the bike up and then pull te clutch in and put it into gear and it pulls away without even letting the clutch out
Edited by fatboyty175
Try and tighten up the cable on the adjusting screw located next to the lever on the handlebars. You may find that as you ride the bike and it gets warm you need to loosen it off to reduce your clutch slipping. This may fix it in the short term but you may need to try changing the oil and possibly having a look at the clutch plates if that doesn't work.
If it only does it on start up dont worry as most do it at one time or another. Try using a good quality light gear oil, Im pressuming youve tried to adjust it as per the manual. If that doesnt work have a look at the clutch basket, the plates wear grooves in the basket where the tags on the plates touch the finger on the basket. This causes drag when trying to release the clutch. This can be cured by gently filing the grooves so the fingers on the basket are smooth again
