donmurray Posted May 11, 2006 Report Share Posted May 11, 2006 The blue rebound adjustment knob on top of the right fork will not turn. Do these freeze up if they are not turned or lubed for some time? Could it just be jammed because someone turned it too tight? Any suggestions? Also, there's a small slot head screw in the bolt at the bottom of the fork. This is the bolt that holds the tube and damper assemble in. What's the purpose of this screw?. Quote Link to comment Share on other sites More sharing options...
joandemma Posted May 11, 2006 Report Share Posted May 11, 2006 This happened to me on a Gas Gas that I bought, don't know if they are the same on the Montesa. Adjusters work by slots clicking on a tiny ball bearing which is spring loaded by, yes you guessed it a tiny spring. On my bike the spring was jammed up with gunk, a tiny grub screw in the side of fork leg top nut is undone to get at this - I had fork legs out as was replacing oil as well. As for the small screw at bottom of leg, I think this can be used to drain legs - pump out old oil. Quote Link to comment Share on other sites More sharing options...
donmurray Posted May 13, 2006 Author Report Share Posted May 13, 2006 Got the rebound adjuster free with some penetrating oil and pliers. Probably too many pressure washings. Quote Link to comment Share on other sites More sharing options...
