superhondaman Posted May 15, 2006 Report Share Posted May 15, 2006 Is the only place to get hold of a LT coil for a 200 Bill Pye's? Quote Link to comment Share on other sites More sharing options...
lee harris Posted May 16, 2006 Report Share Posted May 16, 2006 (edited) oops LT Coil.... I think so. Bill gets them rewound. try getting yours done in Plmouth. (TMX) Hts also available from Steve Goode lee Edited May 16, 2006 by Lee Harris Quote Link to comment Share on other sites More sharing options...
superhondaman Posted May 16, 2006 Author Report Share Posted May 16, 2006 spoke to Bill, said to check resistance first Should be between 580-600 ohms. I have got a multimeter but electrics are well beyond me! at the lowest setting the lcd read out is showing 421 then when i put it on the red LT wire and earth it shows 139? this does not seem right. The multimeter is set to ohms and the lowest setting is up to 2k. Any help appreciated! Quote Link to comment Share on other sites More sharing options...
gasgas249uk Posted May 17, 2006 Report Share Posted May 17, 2006 Will the coil from a 240 work well?. If so i have 2 that i dont need . One has a cylinder shaped body that looks origional and the other is black plastic and looks more modern. Drop me a pm if you interested , otherwise watch evilbay Quote Link to comment Share on other sites More sharing options...
