grib Posted May 25, 2006 Report Share Posted May 25, 2006 Can anyone tell me how much preload I should put on my 240 kickstart return spring when installing it? Thanks. Quote Link to comment Share on other sites More sharing options...
gasgas249uk Posted May 27, 2006 Report Share Posted May 27, 2006 There are 2 springs which control the return. The one i think you are talking about is inside the main gearbox (the other is under and behind the clutch)and as you look at it is hidden behind gear cogs. As i recall the spring should be revolved once and them slotted into place and no more. Terrific tension is not needed , just enough to lift the kick start back . If you try twisting it any more its difficult to slot into place. Its a difficult one to describe , but i hope this helps. Quote Link to comment Share on other sites More sharing options...
