240 Kickstart Spring
grib
There are 2 springs which control the return.
The one i think you are talking about is inside the main gearbox (the other is under and behind the clutch)and as you look at it is hidden behind gear cogs.
As i recall the spring should be revolved once and them slotted into place and no more. Terrific tension is not needed , just enough to lift the kick start back . If you try twisting it any more its difficult to slot into place.
Its a difficult one to describe , <_< but i hope this helps.
