Footpeg Brackets ?
axulsuv
Hi all , I was wondering if someone could go to their 315 or 4t and
measure the frame thickness at the point where the footpeg brackets mount
and the distance between the bolt holes , and from the mount holes to the
center of the footpeg mount ... I have a idea to use some montesa brackets
on my 240 pro to mount modern pegs lower and further back after the O.E.
footpeg stubs have been removed !!! It all depends on the inside width of the mounting area on the montesa brackets...
Thanks for indulging me !!!
<_<
:P
Glenn
Thank you very much ! And looking at what I was planning on doing in greater
detail , with a ruler and cardboard mockup , It's doable but would get complicated at the brake lever mount... So I think I'll just get some modern
style pegs and make them work, The stock fantic pegs leave alot to be desired
even though mine are in good shape . And one more ?... are the hebo pegs
weldable with standard mig wire or would I have to get a special spool ?
Thanks again , cheers
<_<:)
Glenn
And as far as the ten comandments ... So its got a maico 501 top end !
Its period correct...!!## a little port work and it's almost rideable...
Just playing I love the 240 motor .(except for the lack of Ign. parts
available!)
Edited by axulsuv
