Marzocchi Forks On Gas Gas
sir dabs alot
Anyone know the torque specs. for the triple clamp bolts, both top and bottom, on the Marzocchi forks on an '04 Gas Gas?
Also, how much can the forks be dropped in the clamps? 5mm?
The manual says 0mm for short tubes but how do I know if I have short tubes or not?
Thanks!
If you move the forks up the clamps make sure that when the forks are fully compressed the lower stantions do not hit the underside of the lower triple clamp.Torque wise, I have always tightened the bolts hand tight with an allen key then another eighth of a turn to torque up.
