martinh Posted June 12, 2006 Report Share Posted June 12, 2006 (edited) Hello, I have got an '05 290 Sherco. I want to replace the spark plug. The plug I have taken out is an NGK BPR5ES. The only spare unused plug I have is an NGK BP5ES. Looking on the NGK website, they recommend an NGK BP5ES. Do I need the R (resistor) version or is it OK to run the non R version? The bike does have an NGK Plug cap, that does have an ohms symbol on it, so I presume it is has an in built resistor. Also, what should the plug gap be? Thanks Martin Edited June 12, 2006 by martinh Quote Link to comment Share on other sites More sharing options...
andy_290 Posted June 12, 2006 Report Share Posted June 12, 2006 (edited) I bought an iridium one from www.sparkplugs.co.uk edit: NGK BPR5EIX Edited June 12, 2006 by Andy_290 Quote Link to comment Share on other sites More sharing options...
telecat Posted June 12, 2006 Report Share Posted June 12, 2006 I use the Iridium ones in NYL's too! They work a treat. Quote Link to comment Share on other sites More sharing options...
copemech Posted June 13, 2006 Report Share Posted June 13, 2006 The BP5ES is standard, you do not need a resistor. Read my recent post on the 2.0 plug, same! The resistor in the irridium plug may nullify the benifits, primarily the ability to open the gap as much as possible for better ignition in this relatively low output system. The BP5EVX is the direct replacement for the "ES"(non resistor)! But go ahead and experiment and let us know how far you can take the gap on the "IX"! Quote Link to comment Share on other sites More sharing options...
a slack dab Posted June 13, 2006 Report Share Posted June 13, 2006 Try a EVX plug they have worked fine on all the Sherco's that Ive maintained Quote Link to comment Share on other sites More sharing options...
