scoobie Posted June 16, 2006 Report Share Posted June 16, 2006 Hi, I'm going to look at one of these on Sunday that's just had a top-end rebuild. Bloke says that when it's been stood for a while the water pump can take a while to get going and is a little 'noisy' at first. Is this correct, or is he trying to hide a problem? Cheers, Quote Link to comment Share on other sites More sharing options...
sirhc Posted June 16, 2006 Report Share Posted June 16, 2006 The water pump? The water pump is connected to a gear off of the crank so as long as the motor is turning over the water pump is turning. He may mean the fan which is on a thermostat and comes on once the motor gets hot. If it needs to be replaced it's not that big of a deal. Quote Link to comment Share on other sites More sharing options...
