gasgasboy Posted June 18, 2006 Report Share Posted June 18, 2006 I have a 04 Raga and have removed all the road legal wiring looms etc.Could one of you GasGas experts please advise me on how to fit a kill switch.Thanks for any advice. Quote Link to comment Share on other sites More sharing options...
lowbrow Posted June 18, 2006 Report Share Posted June 18, 2006 Hi, If you get a Yamaha type kill switch it should have bullet type connectors on it. Under your tank you'll find only one bullet type connector socket. Stick one wire from your kill switch in that. The other kill switch wire should be taken to earth. Hope that helps. If you've taken your lights off make sure the fan still works! Dave Quote Link to comment Share on other sites More sharing options...
rhaines Posted June 18, 2006 Report Share Posted June 18, 2006 The CDI unit (black box) should have a thin yellow wire coming out of it. Connect this to one end of the kill switch and the other end of the switch to ground. Quote Link to comment Share on other sites More sharing options...
348mate Posted June 19, 2006 Report Share Posted June 19, 2006 If you've taken your lights off make sure the fan still works!Dave My raga has the lights already taken off, how can i tell if the fan is still wired correctly? i havent used it for more than a few minutes at a time ...yet... so fan maybe hasnt had a chance to come on yet??? cheers S.M. Quote Link to comment Share on other sites More sharing options...
rhaines Posted June 19, 2006 Report Share Posted June 19, 2006 If you've taken your lights off make sure the fan still works! Dave My raga has the lights already taken off, how can i tell if the fan is still wired correctly? i havent used it for more than a few minutes at a time ...yet... so fan maybe hasnt had a chance to come on yet??? cheers S.M. Remove the connectors off the thermostat and join them together using a bit of wire or a paperclip. If the fan is wired properly it should come on as soon as you start the bike....simple!! Quote Link to comment Share on other sites More sharing options...
348mate Posted June 19, 2006 Report Share Posted June 19, 2006 (edited) <... run it for longer > I did today and it did come on....(the fan that is!) cheers s.m. Edited June 19, 2006 by 348mate Quote Link to comment Share on other sites More sharing options...
pandelboy Posted June 20, 2006 Report Share Posted June 20, 2006 do yourself a favour and get the kawasaki kill switch as they are better sealed from water ingress, check out at bvm website. Quote Link to comment Share on other sites More sharing options...
gasgasboy Posted June 26, 2006 Author Report Share Posted June 26, 2006 Thanks for your guys help.The wiring diagram was exactly right and it went back together perfectly.My toy lives again.Now i have a pile of wiring looms and road legal gear sitting in a drawer. Quote Link to comment Share on other sites More sharing options...
