Fit Kill Switch
gasgasboy
Hi,
If you get a Yamaha type kill switch it should have bullet type connectors on it. Under your tank you'll find only one bullet type connector socket. Stick one wire from your kill switch in that. The other kill switch wire should be taken to earth. Hope that helps.
If you've taken your lights off make sure the fan still works!
Dave
Dave
My raga has the lights already taken off, how can i tell if the fan is still wired correctly? i havent used it for more than a few minutes at a time ...yet... so fan maybe hasnt had a chance to come on yet???
cheers S.M.
Dave
cheers S.M.
Remove the connectors off the thermostat and join them together using a bit of wire or a paperclip. If the fan is wired properly it should come on as soon as you start the bike....simple!!
